battery type question...
Phil_beeza
461
so i have lights flickering at anything over semi-loud volume
i have done TB2, except for engine-chassis ground
'03 reg, original battery and original 90a alternator
i have 440w+ 150w going out, so not too much really.
the guy at car audio security suggested a cap, till i told him i thought they were bad.
then he suggested a split charge system.
ok..now....
if i bought a battery (maybe from
http://caraudiosecurity.com/shop/product_list/c_path/48_226_366/spd/batteries.html )
and it didnt fix the flicker, i could always spend the extra 50 on a split charge kit, and put the orig battery back in, and use the new one as the second one? (cuz i cant return the batt if it doesnt fix)
QUESCHUNZ.....
does anyone know which of those batteries will fit in a mk4 ibiza, and i assume any of those will work as my primary battery? (ie, they dont have any special wierd specification)
Phil_beeza
461
i am going for a new battery,
someone recommended a vauxhall delco freedom battery
does anyone know
a) what sort of size dimensions i need to worry about for a mk4 ibiza, are the battery securing bits in the ibiza adjustable so i could fit a battery with different dimensions?
b) what sort of amperage or watterage, or whatever other numbers i need to worry about :) what numbers should the battery be rated at
cheers
dainott2105
mk1 Cupra and mk2 FR TDI
Nov 4, 2006
685
swansea
phil if you aint bought a battery yet then get an optima battery. I have just got one of ebay that is supposed to be £180 for £90 delivered (brand new) and it has 910 cranking amps (standard was 400) and looks the muts nuts aswell as it has a smart looking red top and is sealed and fits perfectly in my leon. You wont have any probs with power with one fitted (im running 2 powerful amps which are powering 4 components and a 12 inch kicker solobaric sub) and i was going to put a power cap in the car but didnt need it. Dont look in this part of the site often and would have replied earlier if i had seen this.
PS look on fleabay for the sound deadening aswell. I had mine well under half the price of dynamat and did my boot and all 4 doors for around £35
lard44
Watching C beams...
Apr 30, 2007
474
Braintree, Essex
DON'T GET A POWER CAP! It's just another drain on your charging system and won't make a major difference.
Look at upgrading the wiring, the battery or even the amps themselves - class D mono blocks over AB, that sort of thing.
I upgraded to a 900w RMS mono block along with my 600w 4-channel jobbie, with some 0AWG wiring and I don't get voltage sag (the flickering you describe) until my ears are bleeding. Standard battery.
lard44
Watching C beams...
Apr 30, 2007
474
Braintree, Essex
Caps are useless... they do not store enough charge to make a significant difference on a serious system. They normally supplement insufficient wiring on cheap bass vehicles.
A good quality amp will have an efficient power supply and not require extreme pesks, but does need good clean power lines. e.g. Battery to earth, Battery to amp and Amp to earth. The big three.
Copied from audio website - you can check for yourself. Any audio wiz or research will show you they're not worth the cash.
craig87
beeza lover!
Mar 14, 2007
439
agree cap is a doorstop!!
TB2 is actually supposed to be TB3 grounds are the most important, i have a massive system with my sub amp at 2.5k rms and class ab speaker amp, i have split charge system with massive battery in footwell and i still get lights draining i cant get rid at all, although ive changed to hids and because they are lower voltage they dont dim only the interior lights
craig87
beeza lover!
Mar 14, 2007
439
oh and dont go optima there shite research your batteries, and a redtop is not meant for deep cycle a yellow top is and there not worth the money, look at odyssey or northstar nsb90 if you can fit it in!
craig87
beeza lover!
Mar 14, 2007
439
if your really into your audio you will know that theyre are better batteries for the same money as optima.
Optima are a good battery but the yellowtop has got its name by people who dont know a lot bout batteries buying them cos theyre mates got them and so on, its like vibe, so many people buy it coz all the halords crews have them when budget makes like jbl are much better!!!!
