Battery Lightflashes when Boosting
s5luf
81
Hertfordshire
Hi,
Hope someone can advise me.
When boosting normally in 3rd or 4th gear (well the only times i have noticed it) the battery light starts flashing, engine doesn't cut out, stop boosting and light stops flashing. I have checked all the wires on top of the battery, all are secure and tight.
Has one one had this issue? or advise what it could be
Craig
cjhawker
100
Chester
i second that. mines doing the same (plus get metal grinding noise occassionally). Local garage told me the alternater is on its way and get done asap. Just saving up for it as they aren't cheap buy the look of it
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
Mine was around £120 don't forget once they go, we have DBW and you get no throttle pedal very early on when the battery doesn't receive it's charge.
s5luf
81
Hertfordshire
Im getting some grinding noise occasionally and a little squealling sound when pulling off, doubt aux belt as that was replaced 8 months ago, so sounds like is the alternator - thanks for both your quick replies
Where did you buy the alternator for £120?
cjhawker
100
Chester
£120 seams cheap to me - where is that from?
when i have been looking eurocarparts had one for about £146 but is says out of stock and to ring. other places have been quoting anywhere from £404 - £176 depending on new or recon units.
mine is a bosch 120a 14v
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
Was a local garage specialising in rewinds.
Mine was to far gone to be saved i think, I'm sure mine was a bit discounted and going by your quote shows it was.
i found a new one on the bay for £10 less, but I wanted the "ease" of a local guy if it ever went wrong.
s5luf
81
Hertfordshire
Can you tell me if the alternator is 90a or 120a - and if the standard is Valeo or Bosch?
Called up Seat and they need the part number. I can't see it, so guessing it is on the bottom of the alternator somewhere, or im going blind
Mines the Cupra R 210
Craig
cjhawker
100
Chester
mine had a little white sticker on the right hand side of it (looking head on at the car) i had to get a torch on it and squint a little to read the faded numbers.
