battery help
Dec 3, 2007
2,475
cardiff
any one know how much discharge is coming out of the battery when the car is off? or is anyone able to check theres for me if they have an amp meter. i need to find out how many amps/miliamps the standard or normal drainage is for the cupra.
my battery is dying every day and i have just check and when the secondary water injection is on im pulling .7 of an amp and when its off im pulling around .2 amp when its off.
also my battery is reading 12v volts which i think it should be more around 13v so think my battery might be naffed
any one have any ideas or anyone able to check for me on there cupra?
olethalb
ibiza gone!!!
Oct 9, 2008
252
bracknell
i can check when i get home but it's stood for a week, 12v seems fine when off for a few hours and high 13v's when running usually.
Dec 3, 2007
2,475
cardiff
when its off a battery should be close to 13v there are 12 plates in a battey each holding 1.1v so would give u 13.2v in a battery. so when its off this is what it should be around anything more than 12.5v is normal/good
olethalb
ibiza gone!!!
Oct 9, 2008
252
bracknell
yea was going to do it this morning, but ran past it on the way to work and though - ballax, voltage check! so did one quicky, the car is sumpless at the mo tho. :cry:
Dec 3, 2007
2,475
cardiff
i have come to the conclusion my battery is naf now. but need to know if my car is drawing too much power when its off
Dec 3, 2007
2,475
cardiff
lol. well i checked mine last night and whjen the car is turned off im draining 0.700a for first 10 min then its down to between 0.100-0.300a
