Ok Ibiza Mk5 aficionados' help me out.
My cousin owns a 6J Mk5 2008 Ibiza SC 1.4.
She went away on holiday for a week or so and came back to a dead Ibiza. Nothing had been left on.
First time it happened, her dad charged it up and she took it to a local dealer, who diagnosed a bad battery. Without consulting me, she went ahead and got a brand new battery installed (while the car was under warranty).
All seemed fine on an almost daily basis until she left the car again for a period of 10 days over the xmas period. Came back to a dead Ibiza again. She called Green Flag who came out to her, and he said battery had been drained by something on the car, he suggested alarm (I think unlikely) but said the battery was fine. Gave her a jump/boost and all has been well on a daily basis since. But she knows if she leaves it for anything up to a week or more its likely to be flat again.
Now i've read a thread on here about others suffering similar issues and getting a software update, which may or may not of solved the issue? I presume this is to correctly turn off or reduce the current draw on whatever is staying active after the car is turned off.
http://www.seatcupra.net/forums/showthread.php?t=276832
Also found something similar reported on the RAC forums as well as on some foreign forums.
http://www.rac.co.uk/forum/showthread.php?12604-seat-ibiza-1-4-2009-3-door-repeated-flat-battery
Its pretty poor in my opinion for a modern car to be draining its battery in under a fortnight, for example I left my Leon Cupra parked un-started recently for several months due to some health problems (long story), and it fired up first time like it had been parked ip the day before. Despite the alarm LED going out after a month as I believe it is designed to do.
She again took the car to the same local dealer (won't name them but they are not my favoured choice)
As the car is now out of warranty they wanted £76 to plug it into a diagnostic, which when my cousin complained at the cost they said ok we can do it for £60. Revolving price structure obviously.
Anyway she decided not to pay out and has left it as it is for now, as the car is ok on a daily basis. I think in the colder conditions its only going to be putting strain on the battery and I can see that period of time beginning to drop where it could end up failing after just a weekend parked.
The dealer also suggested that the software update mentioned by other owners is not gospel.
I plugged her car into my VCDS at the weekend and did a full auto scan. It came up with a number of faults, which i believe are only related to the fact the car had no power.
If anyone has had this software update and it solved your issues can you let us know about it, and if you have access to VCDS or are a tech in the know, if the SW number is listed in the logs below can you compare numbers?
Any assistance would be gratefully received, don't believe that anyone should have to pay to have a lead plugged into a car to check the software is at least up to date, at the very least it should be a nominal charge.
Code:
Saturday,12,January,2013,12:29:04:48933
VCDS Version: Release 11.11.5
Data version: 20121222
Chassis Type: 6N0
Scan: 01 03 08 09 15 17 19 25 44 4B 56
VIN:
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine Labels: 03C-906-024-BXW.lbl
Part No SW: 03C 906 024 BK HW: 03C 906 024 BH
Component: MM4HV G 3052
Revision: --H05--- Serial number:
Coding: 0000071
Shop #: WSC 06402 785 00200
VCID: 68D5D1B458CCFE5889C
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 6J0-907-37x-ABS.clb
Part No SW: 6R0 907 379 HW: 6R0 907 379
Component: ABS8.2 front H03 0004
Revision: --------
Coding: 100224DB017100B3082E24E580D500000000
Shop #: WSC 04941 000 00000
VCID: FBFF1EF87E5AC5C0F4E
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 6J0 820 043 HW: 6J0 820 043
Component: Climatronic H07 0203
Revision: S0000000
VCID: E1C34C90F8F60F10CE2
1 Fault Found:
00447 - Function Limitation due to Over-Voltage
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 21
Mileage: 25866 km
Time Indication: 0
Date: 2113.14.02
Time: 15:59:49
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 HW: 6R0 937 087
Component: PQ25 BCM H06 0011
Revision: BF006001 Serial number: 9425A180080021
Coding: 7C8829A88861010000200000660B1CC800C0400F608C00002000
Shop #: WSC 64564 324 38760
VCID: FAF11BFC7560FCC8EF8
Subsystem 1 - Part No SW: 6R0 959 802 A HW: 6R0 959 802 A Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 001 0232
Coding: 030000
Subsystem 2 - Part No SW: 6R0 959 801 C HW: 6R0 959 801 C Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 001 0236
Coding: 020000
4 Faults Found:
00893 - Switch for Trunk Handle (E234)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 4
Reset counter: 22
Mileage: 25898 km
Time Indication: 0
Date: 2113.14.05
Time: 13:26:51
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 8
Time Indication: 0
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 8
Time Indication: 0
01044 - Control Module Incorrectly Coded
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Mileage: 10308 km
Time Indication: 0
Date: 2022.14.20
Time: 05:55:45
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 6R0 959 655 HW: 6R0 959 655
Component: VW10AirbagA0D H07 0013
Revision: -------- Serial number: 003000000000
Coding: 003044
Shop #: WSC 06401 785 00200
ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
ROD: EV_AirbaVW10BPAVW250_SE25.rod
VCID: FF07EAE86642D9E0D86
Crash sensor for side airbag; driver side:
Serial number: 3492ERB402H65FVP63V0
Crash sensor for side airbag; passenger side:
Serial number: 3502ERB402539FQJAROY
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6J0 920 900 K HW: 6J0 920 900 K
Component: KOMBI 017 0018
Serial number: 00000000000000
Coding: 410A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
VCID: 2F677AA876A26960886
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 0011
Coding: 422100
VCID: F0E539D4231CB69851C
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO 017 0018
Serial number:
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156
Component: LenkhilfeTRW V272
Coding: 10121
Shop #: WSC 06402
VCID: EDDB20A0A02E5B707AA
Address 4B: Multifunc. Module Labels: None
Part No: 6J0 959 441
Component: MF-Modul 0007 0001
Coding: 0000001
Shop #: WSC 77005 000 00000
VCID: F0E539D4E31CB69851C
Address 56: Radio (J503) Labels: 6J0-035-153.clb
Part No SW: 6J0 035 153 B HW: 6J0 035 153 B
Component: Radio G3 UL H55 0033
Revision: 0H001001 Serial number: SEZ1Z2H5680944
Coding: 0501040002
VCID: 234F8698226ADD001CE
End ---------------------------------------------------------------------
