Bars Leaks ?
AndyC567
277
Hi all,
Had the cam belt and water pump changed on my Toledo TDI today, and when I collected it the garage pointed out that I had a slight coolant leak from the corner of my radiator..
Not good, I was wondering where the few spots of water were coming from that often appear on my drive. Only get a few, and the level hasn't dropped much, so it is a hardly a gusher !
Anyway, question, has anyone tried Bars Leaks in their coolant, is it any good for a TDI, or is it to be avoided ?
The guy in the garage joked with me not to stick a can of Rad Weld in it as it can cause problems, but is Bars Leaks any better, and will it mix with my nice new G12+ coolant that they added when they did the cam belt and water pump this morning ?
Price to replace the rad isn't to bad £170+vat all in fitted, but after just spending £250 on the cam belt and bits, I could do with waiting a while before I shell out anymore.
Anyone tried it, or know anything about it ?
Ta.
healy6660
Right Old Giffer
Mar 30, 2007
77
Cumbria
It does what it says on the bottle but if you ever need to do anything else on the cooling system you'll have a mothers own job getting rid of all the little slivers of wood out( real bugger if you need a head gasket change)
Holts do quiet a good sealant powder called Sealit i think (available from motor factors) and here are some other options
http://www.doityourself.com/invt/u819409
http://www.autobarndeals.com/servlet/the-6174/Silver-Seal-Heavy-Duty/Detail
(I know its american but surface post.......)
http://www.prestone.com/products/coolingSystemTreatments.php
Good look
