B pillar trim detailing
DANNY H
154
Ipswich
This question is mainly aimed at Leon owners but any advice will be greatly received. Just wondering what you lot use to tidy up the black B piller trim on the trailing and leading edges of the doors. Tried bumper care and poorboys natural look but it still looks uneven abd a bit bleached out. Any ideas?
mrcoyote
See no evil...
Jul 26, 2004
2,624
If it's the bit I'm thinking of, I used CarLack 68 interior/plastic polish on my ST. Not quite a Leon, but the same sort of thing.
mark@carsparkle
Abnormally Large Member
Aug 9, 2005
127
Cold North
www.carsparkle.com
Hi,
Plastic Cleaner is polydimethylsiloxane emulsion - its not water based at all. Also, if you do not like a shiny gloss (unless you want to water it down) then I would not advise CL68-Plastic Cleaner. However, if you do its brill and it contains strong UV filters to prevent plastic from cracking.
If you want a semi matt finish then I would advise you use CL68 Special Cleaner but make sure you wipe it down properly. ;)
