stefa
Hi,
1st post here to look for help with really mystical boost problem:
I have Audi TT225 quattro year model 2000. ECU number is 8L0 906 018 M. Revotechnik software was installed to my car 1 week ago. After SW installation car builds up boost really nicely with gears 1-2-3 but with gears 4-5-6 there is a huge boost drop at 3000 rpm from 1.4bar to 0.6 bar. This happends allways with big gears no matter if throttle is opened at 1000 rpm or 2500 rpm. Once it passes 3000 rpm boost drops to 0.6bar and builds up slowly and then its running OK again at 5000rpm. Look at attached boost pressure charts witch show boost on 3 and 5 gear. This behaviour happends same way EACH time 3000 rpm is passed on high gears with boost more than 0,7bar.
I have debuged the issue with following VAG-COM measurement block data log files. It seems to me that Revo software is asking for some reason less boost after 3000rpm on higher gears (look at boost data difference on logfile with 3 and 5 gear)
Gear 3:
Group C: '115
RPM Load Absolute Pres. Absolute Pres.
TIME
STAMP /min % mbar mbar
0.00 1680 90.2 1710.0 1160.0
0.90 1960 103.0 2070.0 1300.0
1.81 2400 134.6 2250.0 1570.0
2.70 2920 191.7 2440.0 2300.0
3.61 3600 191.7 2400.0 2450.0
4.51 4320 191.7 2330.0 2400.0
5.41 5000 191.7 2180.0 2300.0
6.31 5560 180.5 2010.0 2130.0
7.21 6080 163.9 1890.0 2020.0
'002
RPM Load Inj. On Time Mass Flow
/min % ms g/s
1880 97.0 9.43 36.31
2240 120.3 11.89 54.89
2720 176.7 17.22 100.28
3360 191.7 20.50 128.53
4120 191.7 20.50 158.11
4800 191.7 20.91 184.08
5400 187.2 19.68 191.42
5880 169.2 17.63 190.86
6360 151.9 16.40 181.58
Gear 5:
Group C: '115
TIME
0.60 1640 96.2 1700.0 1260.0
1.50 1720 100.0 1790.0 1320.0
2.40 1880 106.8 1920.0 1390.0
3.30 2000 116.5 2070.0 1500.0
4.21 2160 136.8 2160.0 1680.0
5.10 2320 178.2 2210.0 2060.0
6.00 2560 177.4 2330.0 2380.0
6.91 2760 181.2 2360.0 2370.0
7.80 3000 169.2 1920.0 2360.0
8.71 3160 132.3 1750.0 1610.0
9.61 3320 127.8 1730.0 1620.0
10.51 3480 130.1 1720.0 1640.0
11.40 3640 130.8 1710.0 1640.0
12.30 3760 133.1 1720.0 1650.0
13.20 3920 137.6 1740.0 1680.0
14.10 4080 139.1 1750.0 1700.0
15.00 4200 141.4 1750.0 1700.0
15.90 4360 138.3 1750.0 1680.0
16.80 4480 140.6 1750.0 1680.0
17.70 4640 146.6 1770.0 1730.0
18.60 4760 151.1 1790.0 1780.0
19.50 4920 149.6 1790.0 1750.0
20.40 5040 159.4 1960.0 1870.0
21.30 5200 184.2 2090.0 2150.0
22.20 5360 182.7 2040.0 2150.0
23.10 5520 176.7 2000.0 2100.0
24.00 5640 171.4 1970.0 2060.0
24.90 5760 166.9 1920.0 2010.0
25.80 5880 163.2 1910.0 1950.0
26.69 6000 157.9 1890.0 1960.0
'002
/min % ms g/s
1600 94.7 9.43 29.42
1720 97.7 9.43 33.11
1840 104.5 10.25 37.11
1960 113.5 11.07 43.08
2080 128.6 12.30 53.97
2280 162.4 15.99 74.50
2480 191.7 19.68 89.75
2720 185.7 18.86 97.25
2920 187.2 19.27 107.58
3120 112.0 11.89 69.56
3280 130.1 12.71 83.47
3440 131.6 12.71 86.75
3560 130.8 12.71 89.72
3720 131.6 13.12 94.39
3880 136.8 13.94 101.72
4000 139.1 14.35 108.11
4160 140.6 14.76 112.42
4320 139.1 14.76 114.67
4440 139.8 14.76 119.67
4560 145.1 15.58 128.11
4720 148.9 15.99 134.72
4840 148.9 15.58 136.11
5000 158.6 16.81 151.81
5160 178.9 18.86 181.67
5320 185.7 19.27 189.28
5480 180.5 18.86 189.75
5600 172.9 18.45 186.14
5760 169.2 18.04 186.75
5840 163.2 17.22 183.33
5960 159.4 17.22 181.19
I have changed following parts to eliminate other possible faulting parts before this:
- N75 valve (installed new original= F-model)
- Motor temperature sensor (installed new green original model)
- Spark plugs (installed new originals)
- Air filter (installed new original)
These part changes have not affected the cars behaviour. There is no alarms in VAG-COM.
So what do you guys think about this? Is there a bug in Revo SW on higer gear boost charts or is some sensor sending false information to SW to make false boost peressure reguests at higher gears?
Gear 3:
Group C: '115
TIME
'002
/min % ms g/s
Gear 5:
Group C: '115
TIME
'002
/min % ms g/s
