divvyd
Hi Guys and Girls I have just plugged my 2001 Toledo into Vag Com and this is what I got back........
VAG-COM Version: Release 409.1-S
Chassis Type: 1L - Seat Toledo
Scan: 01,02,03,08,15,25,41,56
Address 01: Engine
Controller: 06A 906 032 CR
Component: 1.8L R4/5VS MOTRG 0005
Coding: 10500
Shop #: WSC 00046
10 Faults Found:
18001 - Altitude Adaptation: Signal Out of Tolerance
P1593 - 35-00 - -
16885 - Vehicle Speed Sensor (G22), Range / Performanc
P0501 - 35-10 - Intermittent
16725 - Camshaft Position Sensor A, Circuit Range / Performance
P0341 - 35-10 - Intermittent
17927 - Camshaft Adjustment: Bank 1: Malfunction
P1519 - 35-10 - - - Intermittent
17852 - EGR Valve Position Sensor, Range / Performance
P1444 - 35-10 - Intermittent
17535 - Long Term Fuel Trim mult., Bank 1, System too Rich
P1127 - 35-00 -
17535 - Fuel Trim: Bank 1 (Mult): System too Rich
P1127 - 35-10 - - - Intermittent
17648 - Cylinder 4 Fuel Injector (N33), Circuit Open Circuit
P1240 - 35-10 - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - Intermittent
16688 - Cylinder 4 Misfire Detected
P0304 - 35-10 - - - Intermittent
Readiness: 0010 1101
Address 03: ABS Brakes
Controller: 1C0 907 379 D
Component: ASR FRONT MK60 0103
Coding: 0013313
Shop #: WSC 00046
No fault code found.
Can anyone point me in the right direction??? I was thinking it might be the coil pack as I have problems with it being lumpy when holding a constant rpm.
I know what the vehicle speed sensor problem is, that is the spindle that attaches to the speed sensor i have that to replace just havent had chance to sort it.
Address 01: Engine
Coding: 10500
Shop #: WSC 00046
10 Faults Found:
P1593 - 35-00 - -
P1127 - 35-00 -
Coding: 0013313
Shop #: WSC 00046
