Are these a bad idea?
Martin M
www.midnightmotors.net
Nov 12, 2006
1,322
Kent
The way you have to bolt them on first, then bolt your wheels to the spacers seems a bit strange.
Martin M
Nov 12, 2006
1,322
Kent
I have never seen ones like that before. I had Eibach ones that needed the longer bolts.
Ben16v
148
Glastonbury
www.gmvw.co.uk
Iv got new wheels with a ET35 off set. They are 5mm in from normal wheels so effectivlly only spaced 15mm each side on the back.
Thing is iv got 2 inches more width than standard wheels but no scrubbage on the back, tiny bit on the front where i havent modified the arch lining yet.
9sorry if i sound grumpy anyone. Only just woke up and couldnt sleep!!!)
Martin M
Nov 12, 2006
1,322
Kent
I see! I changed my wheels for the Ibiza Cupra R Seat Sport OZ Super T's and they scrub out on the back badly. I'm not sure what off set they are though. I might have to get abit of arch modification done and see what happens!
(no worries dude, i wouldn't of said you were grumpy anyway!)
Ben16v
148
Glastonbury
www.gmvw.co.uk
(thats alright then!!!)
Its all in the offset, should be fairly easy to find out what offset they are. Im surprised they scrub though as i run 16x8J all round and mine sits farily low.
Sure a bit of modification will sort it!!
roly
midnightmotors.net
Jan 2, 2002
1,879
Midnight Motors Workshop
ET35 on the Seat Sport Rims
they rubbed on mine that's why i changed them to an ET37, no probs without spacers but a bit on hard cornering and bumps with a 15mm spacer
Ben16v
148
Glastonbury
www.gmvw.co.uk
Reccomended my many by the looks of it, It does make the back end stick so well. I was pushing mine past the limit of where it used to start to go in the dry when it was wet on sunday at stuck a treat.
Pirreli (spelling!!!) P-Zero Nero reccomended as well!!!
