Hi all.
Since my one month on this forum, I have been reading avidly and have noticed that quite a lot of things go wrong on Leon's albeit they may be small problems which cost next to nothing to fix such as...
Failing coilpacks
MAF sensors
Water leaks
Now I will be buying a Cupra R and must admit I don't know much about how a car works or what everything under the bonnet does. I will be going to the Cupra R from a Mazda MX5 which, in my 4 years of ownership, only had one problem which was a failed electric window which was fixed for £60 in 30 minutes. Normal stuff such as draining the waterholes I do myself once per year which involves sticking a sharp object in two holes under the car.
My greatest fear is that the Leon will be too much of a handful for a novice like me. Does this mean I should be looking at other cars or should I still go for the Leon? For example, I don't want it breaking down on me in the middle of a drive as this would terrify me.
So seriously, how many problems will I encounter per year?
Cheers - Cobraman2007
Failing coilpacks
MAF sensors
Water leaks
