AP Racing brake replace SEAT Cupra 6J (question)
The brakes will fit
  • Yes
  • No
Results are only viewable after voting.
Bas H.
26
Hi SeatCupra.net,
Thinking of replacing the Brake Discs and pads myself. I got the SEAT Upgraded Sport brakes from AP Racing. Problem is: I dont know which products to use.
I can't find which braking pads/discs should be for my car. Tried to check up the PR Code but that didnt helped out either. I checked up the original part numbers and found the following products on Autodoc but I dont know if the products would fit...
Original disks front:
8N0615301A
Found: https://www.autodoc.nl/brembo/7887475 (P/N Brembo 09.7880.1X)
Original pads front:
6LL698151
Found: https://www.autodoc.nl/brembo/7887647 (P/N Brembo P 85 134)
Original disks rear:
2Q0615601H
Found: https://www.autodoc.nl/brembo/7887399 (P/N Brembo 08.7165.1X)
Original pads rear:
1J0698451P
Found: https://www.autodoc.nl/brembo/1661875 (P/N Brembo P 85 020)
Anyone can tell me if the brake + pads above will fit? All are brembo discs aswell as pads but I dont know if they'll fit at all. I dont see the PR number comming back on the car. Putting the codes in a PR converter does not give me any information aswell.
I do have the AP Racing 4-pot upgraded brakes.
xChokis
29
So these are 230mm's not 312mm's right? Looks pretty cool though and for 200€ seems like a huge update! Keep us updated on this one!
Mar 10, 2019
At rear yes 230, but u can put 256 from Leon Cupra I, Audi TT but bot from quattro. Front breaks at ETKA shows 312 max. If u don't have and u got 288mm, u only change the carrier with the designation 451, fit from S3, Leon I, Golf IVIV G from years 1999-2002
