acidstrato said:yeah i know what you mean, but the question is, is there?
everyones too concerned with broken mafs that theres barely an answer to the question
and as for hot air...well has anyone touched a turbo? would it really make that much difference?
flashbsd said:good lad martyn, worth posting that stuff in a new sticky at the top of the mk3 section?
I find the green panel filter best out of all kits ive used, dynatwist, open, hurricane etc. SO long as youve removed the standard restrictive pipe from the airbox, your better than you were
thanks martyn for pointing that out.
David_smith_909 said:iv heard some induction kits will only work properly up to a certain bhp (please correct me if im wrong)
does anyone know how much the jabba will take until its starts to ........ well ............ not work properly ????
David_smith_909 said:yes, but for example on the BMC website it tells you what sizes are etc .... but it also tells you what bhp is recommended for each filter
Martyn said:Alex, the small pipe that feed the airbox from the wing. It's also good to smooth out the ridges inside the box
Dave, you'd need to call Jabbasport to find that out mate. I know some of the 300+ IHI boys have them on their cars though.
SeanyK said:The pipe is a nightmare to remove unless you take the wheel arch out, so you'll need to jack the car up.
Did my mates Cupra, was a bit of a mission.
Worth it though, although I havent removed mine yet! Lol
Im also possibly looking at a green panel filter
