anyone used these drilled pads and discs for LCR..
James D1
Pre-facelift
Aug 2, 2012
255
Essex, Uk
i have a cheap set of drilled and grooved discs and they work wonderful. tonnes better than standard. (i have a lc180 though)
RICKY3
1,002
AYRSHIRE
You would be better with dimpled an not drilled as the holes can crack. If its for road use stick to plain discs as grooved are a bit louder an wear pads quicker
Sent from my iPhone
k1_cupra
66
Sent from my iPhone
should i just go for pagid discs then? car wont be used on track. what pads would you reccomend? green yellow or red stuff pads any good?
Exe_LeonCR
Exeo ST
Feb 12, 2012
284
Devon
Sent from my iPhone
second that...just swapped from dimpled grooved discs to standard and loads quieter and fine for road use.
