No.Does this mod mean you lose your 'High beam' though?
I perhaps should have made explicit, this mod is only for folks with factory bi-xenons, which means that both dipped and main beam functions are done by the bi-xenon unit (the big round projection lens you see in the pics above).
On such cars, the 'high beam' reflector is redundant so they've used it for DRLs, with a 382 type tungsten bulb in the position where the high beam bulb would go on a non-bi-xenon model.
This mod is simply replacing the existing DRL bulb with an equivalent LED unit but the function hasn't changed at all... they just light up (by default) during the daytime when the ignition is on and the lights are in either OFF or AUTO position.
