Hi All,
I have been experiencing cold start problems with my Toledo 110 TDI..
I wait for the glow plug light to go out (about 5 sec on a cold day) but then it never starts.
But, if I turn on the ignition, wait for the light to go out, then turn the ignition off and then repeat again, it always starts straight away !! Glow plugs must be working then ?
Starts fine when warm to..
I have replaced all 4 glow plugs thinking they were the problem, but it still does it.
So my current thinking is that the glow plugs may not be on for long enough.
What do you guys think ?
So, I have been recommended to change the Temp sensor (thanks Sarah) as this plays a part in controlling the glow plugs.
I have measured the Coolant temp using Block 1 on Vagcom and it doesn't seem far out on a cold icy morning (maybe a degree or two higher than ambient indicated by the clock), but I want to change it just in case.
I have a new Green top version of the sensor which I got from GSF (tad under 20 quid), but the thing is, I can't find the sensor fitted on the car !!
Does anyone know where it is on a TDI 110 (non-PD) engine ?
I have removed the engine cover, but still cant find it !
I have tried searching, and found loads written about these sensors, but no information as to where it is on this engine..
Any help or maybe some pictures would be really appreciated.
