Anyone have the wiring for the MAP sensor?
xillius200
19
Just after getting my intake back on and using the car for a day or two. I was screwing a bolt back in I missed, dropped the ratchet and seem to have taken out the wires from the MAP sensor. Can't seem to drive it at the moment as after a minute or two of the engine being on sounds like the turbo is spinning up with a lot of boost, doesn't seem to want to run without the sensor and I get a P0238 error code, got a new 3 pin plug to splice the wires together and connect back up so hopefully will fix it, anyone happen to know which wires go where?
I have a black, brown and green/purple wire
Pin 2 was blocked out on the plug and not used
Reactions: KCRTCupra
xillius200
19
Didn't get a reply in end but managed to get it sorted, in case anyone else has the same/similar issue, rather than messing around with the plug, if you search ebay can get a plug already wired "VW 4 PIN MAP SENSOR PLUG CONNECTOR"
pin 1 is brown
pin 2 is yellow (wasn't needed)
pin 3 is black
pin 4 is lilac/green
at least for a 2010 cupra
