Anyone have the fuse setup? for w8 light
Oct 11, 2008
714
Bristol
Hi all
im trying to install my w8 light and want to remove the fuse rather than disconnect the whole battery.....
so does anyone know the setup or the position of that fuse?
many thanks
gus
476
Im geting one very soon what do u mean u have to might disconnect the battery matey???? Did u do it all ur self??? Is it hard to do?
Oct 11, 2008
714
Bristol
i was worried about grounding th dimmer cable (blowing the use) so i was wondering which one was the interior light fuse......
i did fit it myself and the only thing that was time consuming was fitting the dimmer lead.
it looks great i just need to put some photos of it.....
RichieRich
Mk4 Golf GT TDi
Sep 17, 2005
2,367
Oxfordshire :)
www.bebo.com
umm take a look in ur manual matey it will tell you in there, the w8 light is peasey to install in the beeza did it myself twice :) im now getting one for the golf which is going to be harder as u cant get the cable from the right hand side of the dash.. :(
gus
476
yeah getteing the w8 light it looks like a bit of a mission to connect it to the dimmer wire.
RichieRich
Mk4 Golf GT TDi
Sep 17, 2005
2,367
Oxfordshire :)
www.bebo.com
easy on the beeza matey, take the side pannel off and its in front of you :) peel the protective plastic from around the wire solder the new one to it or twist it if u cba to solder it then put a decent amount of tape around it job done :)
