Welcome to our new sponsor Lecatona, a brand dedicated to enhancing performance for VAG group sports cars, including SEAT, Audi, Volkswagen and Škoda. Specializing in High Pressure Fuel Pump (HPFP) upgrades.
Also any ideas how many amps can go through the lighting wiring without causing damage? need to upgrade the tiny 7.5 amp one again! (already put a 10a!)
Got no phone signal down in sunny kent! Basicaly my hids would flicker n and then off when i switched them on, switch off and then on and all worked fine! I fgured it wasnt faulty ballast as it did it on both sides, every time! I looked at the fuse and saw that there only 7.5 amp and i read somewhere that the HIDs draw 17amps when warming up. Put a 10amp fuse on both sides and hardly ever gives me a problem now, but occasionaly does, how big a fuse can i use without causing damage to the lighting circuit??
my HIDs have ran fine for the past 2 months since i installed them, they only have a 7.5 amp fuse. However if your havin problems, installing a relay should solve your power issue.
Will this do the job??? Not realy sure and dont have the equipment to wire up relays myself! Found a diagram that sort of explained it but dont wanna make a mess with wires everywhere!!!
mines got a 10A in and cant say ive had any problems in 6 months
it only draws 17a for a split second on start up current so not enough to blow a 10a and the standard wiring will take 17a for a second easy 20a wont cause any problems will still blow the fuse before messing any wiring up
