Anyone got a JVC AVX-1 Head Unit in their LCR?
Craigc
238
Edinburgh
Here are the pics -
Close up -
The stereo does stick out a little from the dash due to it having quite a thick face plate.
zorba_the_greek
The plate smashing Greek
May 22, 2005
118
North London
www.cliosport.net
Im currently looking around for the lowest price
saw them for like £380 at a shop near me.
where did you get the plastic facia from that goes round the unit??? halfords
did you use kebab sticks to get the original headunit ????
and was a simply connecting the car to the unit
Craigc
238
Edinburgh
I think mine was around the same price.
Yeah just get the facia from halfords or your nearest Seat dealer. They cost about £10
To remove the old stereo I just used the JVC security keys
zorba_the_greek
May 22, 2005
118
North London
www.cliosport.net
are the buttons red to match the dash back lighting or blue.............cant really tell?
craig if you have anymore pics from the side and with the unit face taken off it would be great! just want to see when i lock the car if you can see much. i.e. is there a red security flashing light???
whats the sound quality like with the standard cupra r speakers.............can you tell the difference???
Craigc
238
Edinburgh
There aren't many buttons, the ones that there are light up blue wich can'b be changed. Only the screen background can be changed.
There is no flashing light when the facia is removed.
The sound quality is good as the standard speakers are actually quite good.
Baz1
216
Leicester
I have one too.. .. awesome piece of kit. Looks the mutts nutts!!
Sound wise, its very very good, poss not as good (IMO) as the JVC SH909R that I had previously.
Baz
stuart_hatch
Poor Student
Aug 28, 2005
318
Glasgow
Craigc said:
If I had one gripe it's the controls are a bit clumbsy. It is not straight forward to change radio station
Your right there, on firmer suspension its a pain to change stations, oh and to get around the not being able to play dvd's when driving, crimp the handbrake sensor wire to the negitive
LeonDK
91
Malmö
@ Craigc
You can modify the 2 "flaps" on the side of the radio and with this install the radio app 8mm deeper.
I did this with my VDO Dayton navigation, Result is much nicer and it dosent look like the radio tries to touch the reasr seat...
BR
LeonDK
Gizmo
53
LeonDK said:
@ Craigc
BR
LeonDK
Just got the JVC :D
I can't quite visualise what you'd mod to make it fit deeper :confused:
Do you install the cage first and then insert the JVC through the Autoleads facia adaptor or the other way around :confused:
Then what do you recommend trimming - I assume you mean the Autoleads facia adapter :confused:
LeonDK
91
Malmö
Hi,
It is quite easy.
Out with the Aura radio and in with the cage for the JVC unit. If you put in the 2 flaps first the cage will be app 8 mm further out.
Now you modify the flaps by cutting of the plastic that normally would be behind the radio/cage - Then you fix the flaps with some "gun gum" or similar tape.
Connect the radio - push it in and be happy that it is looking more OE as the normal installations we see...
Hope it is clear now...
Gizmo
53
Cheers for that.
I've used the Autoleads facia which goes completely across and behind the cage but is only about 5mm thick.
Looks pretty good but agree it would be better if it was back a bit further.
