thanks man
cant exactly remember the sizes of the bolts etc
but theres 2 t25 (i think) screws holding on the plastic cover under the bootlid, take them out and remove the cover undo the bolt holding the wiper blade on, then undo all the bolts inside the cover that hold the motor on give it a wiggle and itll pull through then put a rubber gromit on the hole (or a glass bond in if your flush)
remove the washer pipe or block it up
sorry its a rough
guide but its easy when you see it
