any one??? know about tb's?? got codes
danielc16
cupra R dan
May 13, 2008
327
guildford
right i got my mum to buy be vag com :) so now i know all the codes!
this is my fault codes:
Tuesday, 20 January 2009, 11:38:41
VAG-COM Version: Release 409.1-US
Control Module Part Number: 6K0 906 032 AB
Component and/or Version: 1.8L20VTCUPRA R 0001
Software Coding: 11500
Work Shop Code: WSC 00000
7 Faults Found:
17953 - Throttle Valve Controller: Malfunction
P1545 - 35-10 - - - Intermittent
17967 - Throttle Valve Control part (J338): Fault in basic settings
P1559 - 35-10 - - - Intermittent
17950 - Angle Sensor 1 for Throttle Actuator (G187): Implausible Signal
P1542 - 35-10 - - - Intermittent
17579 - Angle Sensor 2 for Throttle Actuator (G188) Implausible Signal
P1171 - 35-10 - - - Intermittent
does any one know is it a new tb or wiring?:cry:
Forbez
Huge Member!
Feb 11, 2004
5,878
S.Wales
Have you tried clearing them and seeing if they come back?
It may be from sometime ago, and they were never cleared. If the problem is still there, then they will re-occur.
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Good luck,
I have the exact same codes.
I`ve bought a known working 2nd hand TB and also used another from a members car but to no avil, also tryed his ECU while he was here.
Had a garage looked at it and he just tryed to fob me off with a load of shite because i dont think he had a clue.
Seat wouldnt touch it nor a local VAG specialist because of the mods i`ve carried out, so i`ve had to hire a low loader to drag it down to Bill`s with hope he can sort it out.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
Good luck,
I hope I can too..
fingers crossed
:blink:
