check you fuel housing and boost pipe
this will be a prime suspect then if not start looking into the rear engine mount if not there then look into bushes if not there then look into exhaust if not there look into transmission
please make sure all wheel nuts are TIGHT! trust me this is so common! then check glove compartment and spare wheel well for loose parts
sure ive covered everything
