Another Heater Thread...
AdamHarling
142
Bath
Hi All,
I seam to have a fairly common problem...
My heater blows luke warm air on every setting other than HI (which is then DAMN hot).
After searching I found that many people say changing the outside temp sensor sill sort this.. HOWEVER...
My display reads fairly accurately... 4c on the display... fecking cold outside... 10c on the display.. not so cold outside... so I think that sensor is working fine...
I found another thread that said the air temp for the air-con was read as in enterered the heater...
SO.... anyone know what I should do... would be really great if I could set it to 22c and leave it there.. instead I have to have the occasional blast on HI to make it comfortable.
Cheers for any help guys!!
Adam.
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
I think its all joined in with the auto climate control mate, as when it was very cold the 28c seemed farily warm but when the weather is quite mild like it is now it seems to be lukeish warm, However i think that when you have the HI turned on its that bloody hot that when you switch it to a lower setting it seems like you have just walked into a fridge! Again my outside temp seems pretty accurate too.
david.
