Hi all,
I have just got to the bottom of my last boost issue which turned out to be a faulty N75 which has now been changed. Cars boosting fine again way over 20psi peak.
I now have a new problem when I hit peak boost in 3rd it seems to vent about 5 psi off instantly. I get a little pssssh noise like the dv is venting i can see it on the guage dropping instantly. It then goes on to hold boost as normal so i don't think it's a leak.
Could this be the dv? I'm running a green spring but never really had any problems before, and it's been recently serviced? Also it's only doing this in the higher gears presumably becaue there is more load
