Hi I don't know if anyone can come up with a solution to this
problem? I have an altea on 54 plate the radio has developed a mind of its own. When the car is parked and locked (so alarm is on and the ignition off). The radio comes on at full volume. This of course causes a voltage drop if not notice which sets the alarm off. The car has been to the seat dealer who replaced a circuit board, but at the moment every few days the radio just turns itself on. Went back to when radio turned on again but it does not do it in garage so Seat dealer cannot find wrong.
Hi davety - a common
problem on ALTEA's there was a thread about this a while back and about aircon problems not sure if still available. As mine was under warranty new radio fitted by SEAT. The old thread I referred to had some DIY fixes which I copied to a WORD document the thread said:-
"Radio switching itself on by it's self and sometimes running the battery down?
For the record to solve the radio switching on by itself one “solution” is to leave a CD in it, as this
problem seems to be related to a micro switch which must get jarred by moving traffic when parked up. It's fuse 56 under the drivers side that is the main aircon fuse [2004 model with climatic control].
Previous reply from forum member - Thanks, I did this pulled out fuse 56, turned car on to make sure the fan was not working, then turned car off, replaced fuse and Cruise Control has worked every time". (Also fixed the radio issue too)
Hope this helps the original thread was number 111967 (I'm not able to post full links!!) and was about aircon/cruise control and radio problems as it seems that the same fuse 56 controls all these 3 items.
These faults (especially the radio) did seem to affect 54 plate models more than later years and I understand that SEAT modified later year cars with a fix as stated on the original old thread. One owner on the forum traded in their 54 car for a 07 model and the problems seem to have been solved.
Patrick
