Hi all
Hoping someone can help.
My issue seems to arise after about 45 mins of driving.
Mainly long journeys.
I have my climatic control set to 19c. Blower fan works fine, I can notch up the fan speed manually if required. After about 45 mins, the air flow drops to near nothing, the setting on the dash is on full bars, eg top speed, but it's like the system has given up. The temperature in the car starts to creep up. No matter what I do, I can't get the fan speed back to normal flow rate.
The following day, everything is working fine.
Only seems to happen on long journeys when the climatic control is in use for longer then 40 mins or so.
Has anyone had such an issue?? If so, any help on a cure would be appreciated.
