littleade
Hi all, picked up a 1.9 tdi rerence sport last friday and am very pleased with it. Only gripe so far is the arial and it's position. it keeps snagging on my up and over garage door when i open and close it which results in some nasty twangs if I don't pull far enough into the garage. "drive further in" I hear you say but the problem here is that I want as much room at the back of the garage as possible as we use the side door to get in and out and there's only a small gap between the front on my nice new car and the tumble drier and freezer. there's a good few feet between the back of the altea and the main garage door which I could use if i had a smaller arial or a different type. My dealer suggested I cut a few inches off the end which seems a bit extreme. I can't angle it down flat by unscrewing the thing as it would catch on the tailgate when it's lifted up.
has anyone else had this problem and come up with a fix? I've considered reversing into the garage, but the layout of my property makes this awkward and there's not sufficient clearance on that side of the garage to be able to open the drivers door.
Thanks Ade
Thanks Ade
