Hey Guys,
I have a 2004 1.9 Altea S and it is blowing oil back onto the firewall. It is happening on the top half of the engine, to the left as you look down onto it. It is towards the rear as there is no trace on the front side of the engine.
I'm wondering could it be a turbo issue?? There is a hiss as you apply the power, a friend of mine has the same car and this does the same hiss but I'm wondering if mine has gone onto some next step. Also, when you remove the dip stick or the oil filler cap there is a white steamy rise as the engine is running and possibly I think, a little bit of back pressure. I don't know if this is normal......??
Could it be a rocker cover gasket, head gasket, dodgey pipe? There is only 102000kms on the clock......
It ain't using water or overheating and has not used oil up until it started throwing it out.
Has anyone had this before??
Anyone have any clues?
Is this one gonna cost me????
Thanx guys!!
Gavin
Thanx guys!!
Gavin
