Alarm problem!
MM
Hi guys!
I have a problem with car alarm.
The car is seat ibiza 1.9 tdi sport [2001]
Today when i wanted to unlock the car with remote on the key, nothing happend!
I tried several times, but the car remained locked and the red led on the door continued to flash.
Because i was in hurry, i manualy unlocked the door, but that triggered the alarm horn.
Earlier, i was able to turn off the alarm by the turning key to ignition position, but not today!
Then i tried to pull the key out, and then back it in place and ignite the engine again, but the alarm sound remains.
I had no other choice than to drive car with alarm sound and blinkers turned on!
Later (after the exam :D), i have pulled out several fuses, and determined which one is responsible for horn. (fuse No#27)
Now only blinkers are flashing periodically, but there is no more horn sound, and i have to lock and unlock car manualy.
Can You please give me some advice how to solve my problem?
Thank You in advance!
Mark_vRS
Full Retard
Feb 22, 2010
141
Blackpool
i have just had pretty much the exact problem recently!
I disconnected the horn and pulled out the hazard lights fuse to drive the thing
Turned out to be a faulty fob, got myself a new'un, coded it in and everything was sorted :)
Try recoding your current fob first though.
Mark
MM
@Mark
Thank you for the quick answer!
Can you, please, give me some detailed instructions how to re-code key?
I saw something on the net, but the instructions are not quite understandable.
1 - insert second key and ignite the engine
2 - wait for 5 seconds, and then turn off and pull key out
3 - press and hold unlock button, then three times press lock button, and release the buttons. Then after the light on remote blinked five times -
4 - press unlock button
5 - ignite the engine
Is the instructions right?
Mark_vRS
Full Retard
Feb 22, 2010
141
Blackpool
yeah pretty much
1. insert key, ignition on
2. ignition off within 5 secs
3. remove key, hold lock button down and press the unlock 3 times
4. remote LED should start flashing and the car should try locking/unlocking itself
5. insert key, igniton on.
Then try the remote locking.
mine flashed but the car didnt try locking/unlocking itself...
bluescoot
Hi mate, I've got a mk1 leon cupra and I had pretty much the same problem, I traced it back to a dodgy battery, turns out if your battery is flat or not holding charge it sets the alarm off if you unlock the car without the fob and start it.
keenocupra
81
stirling
alright . i had this problem with mine and it turned out to be a sticky ignition barrell. basically when u remove the key it still thinks the keys in. when u take ur key out does the radio stay on? if so u may need a new barrell
