Aircon pipes 1.2 SX
Roland2937
I parked up the car after a longish run on a very hot day. There was water dripping down the back of the headlamp cover which was odd. This seemed to be coming from the pipes which rise behind the left of the radiator and then run inside of the bodywork to the bulk head. The pipes look like a combination of sections ordinary hoses and alloy. Where the water seemed to be coming from was a plastic valve at the top.
Can anyone tell me if this is normal and what the valve is for?
Roland
Cal91
1.4 Powerrr
I'm not too sure.
But I do know mine drips if I have had the AC on for a while.
Its condensation build up on the pipes because they are that cold.
After a long run, a large puddle of water can form under the car.
This is normal but I have never had a look to see where the water is actually dripping from.
Roland2937
Yes, there was a fair bit of water dripping from under the bulkhead. But from pipes right behind the radiator seemed a bit odd.
kidinspace
Service Desk Specialist
Dec 3, 2008
1,227
Glasgow, Scotland
www.flickr.com
Hope this helps.
The numbers on the image are the numbers in brackets on the parts list.
Partlist:
refrigerant condenser / AZQ,BBY,AUB,
fluid container / refrigerant circuit
/ ASY,ASZ,ATD, AMF,AZL,BBZ
1 6Q0820411B
refrigerant condenser / F >> 6L-3-044 431
(1) 6Q0820411E
refrigerant condenser / F 6L-3-044 432>>
(2)
refrigerant compressor / see illustration:
260-15 /
3 6Q0820721N
refrigerant hose / (refrigerant compressor > refrigerant condenser)
/ manual- gearbox: AUB,BBY,BBZ
(3) 6Q0820721M
/ automatic: AUB,BBY,BBZ
(3) 6Q0820721S
/ AZQ
(3) 6Q0820721L
/ ASY
(3) 6Q0820721H
/ ASZ,ATD,AZL
(3) 6Q0820721R
/ AMF
4 6Q0820744F
refrigerant hose / (expansion valve > refrigerant compressor)
(4) 6Q0820744N
(4) 6Q0820744M
/ ASY
(4) 6Q0820744AA
/ AZQ
(4) 6Q0820744L
/ ASZ,ATD,AZL
(4) 6Q0820744T
/ AMF
5 6Q1820743E
refrigerant hose / (expansion valve > refrigerant compressor > refrigerant condenser)
lhd / AMF,ASY,ASZ, ATD,AZL
(5) 6Q1820743F
lhd / AUB,AZQ,BBY BBZ
(5) 6Q2820743E
rhd / AMF,ASY,ASZ, ATD
(5) 6Q2820743F
rhd / AUB,AZQ,BBY, BBZ
(5) 6Q2820743G
rhd / AZL
6 6Q0820741A
refrigerant hose / (KAELTEMITTELKONDENSATOR> / TRENNSTELLE)
6Q1 820 741 .. /
(7) 6Q1820741L
refrigerant hose / (TRENNSTELLE > / EXPANSIONSVENTIL)
lhd 6Q0 820 741 A / AMF,ASY,AZL
(7) 6Q1820741J
lhd 6Q0 820 741 A / AUB,BBY,AZQ, BBZ
(7) 6Q1820741M
lhd 6Q0 820 741 A / ASZ,ATD
(7) 6Q2820741L
rhd 6Q0 820 741 A / AUB,AZQ,BBY, BBZ
(7) 6Q2820741M
rhd 6Q0 820 741 / AZL
(7) 6Q2820741N
rhd 6Q0 820 741 A / AMF,ASY
(7) 6Q2820741P
rhd 6Q0 820 741 / ASZ,ATD
8 6Q0820771A
bracket for refrigerant hose
9 N 01396921
oval head panel screw
4,8X16 /
10 811807577C
insert nut
11 8A0260749AJ
round seal
10,8X1,8 /
12 4D0260749A
seal
23,80X2,40 /
13 1J0820749
round seal
14,3X2,4 /
14 1J0959126
thrust sensor
15 357820809B
protective cap
16 357820795H
valve
17 357820809C
protective cap
18 357820795J
valve
19 701820774A
dual clip
20 6Q0816811A
21 321820061D
gasket
1220X12X10 /
22 6Q0820769B
bracket for refrigerant pipe
/ diesel eng.: ASY,ASZ,ATD, AZL
23 N 90817002
torx socket head panel screw
6X17-Q /
24 N 10414401
allen key head bolt
M8X28 /
25 N 90455301
hexagon nut, shouldered
5 /
27 N 10115306
cheese head bolt
M6X12 / diesel eng.: ASY,ASZ,ATD, AZL
28 N 10067003
hexagon head bolt c/w shoulder
M8X92-V /
29 N 0206472
pipe clip
B15X24GI /
30 1J0820749
round seal
14,3X2,4 /
31 8A0260749AJ
round seal
10,8X1,8 /
32 6Q0298260A
repair kit for quick release coupling
NW-13 /
33 6Q0820193
drier / F >> 6L-3-044 431
(33) 6Q0820193A
drier / F 6L-3-044 432>>
34 6Q0298260
Roland2937
Thanks, the diagram is useful.
Do you know what liquid is in these aircon pipes. Is it part of the coolant system ie. connected to the radiator system or something else ?
RUM4MO
7,967
1,059
South Scotland
The liquid/gas in these pipes will be R134 - it could be that your system is "short" of charge so now needs re-charging and that is what is causing the pipes to be chilled where they leave the condenser.
