Air Con Noise
NorthWalesPie
Hi All,
We have a 1.4 SE Ibiza and the car is great BUT!
The air con has started making a noise. Has anyone else had this problem?
Just for info really before we take it back to the dealer.
Steve
NorthWalesPie
It sounds like a bearing noise. As soon as we press the A/C on (climate control) you can hear it above the engine.
It comes through the air vents.
NorthWalesPie
No. The fan sped just hides the noise when on LO and the fan is full on.
iandjm
272
Isle of Wight
Hi All,
Steve
The compressor on my car is noisy too. You can definately hear when its on (most of the time as I have climate control) I was wondering if it is a fault or just a noisy compressor?
Ian
jools
Hi, yes mine is exactly the same. The more load on the compressor- ie on a very hot day the more noticable the noise. Turning off the ac stops the noise instantly.
My previous mkiv Ibiza was even worse, the noise was there from new although it never got any louder in the year I owned it.
To be honest I don't think this can easily be fixed, even changing the compressor is no guarantee. I think the problem is due to the operating noise of the compressor being transmitted into the car via the air con pipes. Possibly due to the way they are routed and also a general lack of noise insulation.
Be interested if anyone does get it fixed though!
NorthWalesPie
I will let you know how I go on at the dealers.
The noise was not there until a few days ago.
Thanks for all your help and comments.
Steve
