Air bag light mystery
calmarshall
Orite ppl...
Recently i got my self a seat ibiza cupra tdi... when i was giving the car a hoover out i noticed a yellow plug and socket taped up underneather the seat, i took the tape off and the plug wasnt into the soket, a resistor had been put between two of the cores as if to link something out... i took the resistor out and plugged it in how it seemed it was ment to be and now the air bag light is on constantly even when i put the resistor back in...
anyidea wots going on? :confused:
cheers cal
Nath.
The Gentlemans Express
Jan 1, 2006
8,620
16
EASTLEIGH, HAMPSHIRE
The resistor is a bodge, by removing it you have caused an air bag fault and this fault will not go until it is reset with vag com or at a dealer.
muddyboots
Still hanging around
Oct 16, 2002
5,739
Sounds like one of the airbag components is faulty, and rather than fix it, someone has just bypassed it with a resistor to fool the Airbag ECU that all is OK.
Pretty dangerous really, as it means something ain't going to protect you in a crash.
Whether it's side airbags, or seatbelt pretensioner, I don't know.
The airbags & pretensioners in the Mk4 are one of the reasons I got out of my crash last year pretty much unscathed.
If it was my car I'd be getting it fixed ASAP.
Nov 27, 2006
1,204
www.cardomain.com
Do the seats that are in it now have an airbag label on the side ?
Sounds like someone could have swapped the seats over and used a 5ohm resistor because the 'new' seats don't have airbags in them (that what I did with the Recaros in the Toledo)
...either that, or they've just put the old seats back after having aftermarket seats in it before, and just not plugged them back in :confused:
Might be worth disconnecting the battery, plugging the yellow connector into the seat (if you can find a socket) - leaving it for an hour - re-connecting the battery and seeing it that resets the fault code.... if it appears again, there's a fault with the airbag in the seat
calmarshall
I'm guessing someone disconnect the airbag :| Kind of sounds a bit serious, has the car been in a crash before?
OMFG! We have the same name :D I'm called Callum Marshall too.
Yea i think the car may have been in a crash as u can tell the front windscreen has been replaced, it hant got the SEAT marking its made by a different company...
yea cal marshall is a mint name mate ;)
calmarshall
yea mate they have the airbag label on the side. yea i will try tht trick with the battery and i will let u know. cheers mate
calmarshall
cheeers for all the info lads i will keep yas posted
So is the plug and socket under the seat only for the side air bag in the seat?
muddyboots
Oct 16, 2002
5,739
Not sure - IIRC, it could also be for the seatbelt pretensioner, which I think on the Ibiza is mounted to the side of the seat nearest the handbrake.
kenny-cupra
Newbie
Sep 7, 2005
334
Renfrew
can you tell me what size of resistor you used , and did you connect it across the 2 colours rather than the brown cable as this is a ground
Kenny
calmarshall
which out of the 3 wires am i putting the resistor in if i put aftermarket seats in mate?
Nov 27, 2006
1,204
www.cardomain.com
Blue and Black on your seat plug
marshey
203
essex
Sorry to revive old thread but I have just tried this with 5ohm resistor and it hasn't worked. Any pics of the resistor and plug completed.
marshey
203
essex
Right ok thanks for that. So I'm in need of vag com now then. Do I buy it or do I see if a member can do it for me.
