Air bag fault - 01222 help
struds
Vag Com has picked up a fault on my airbag - i knew it was there as the light was on...
so having used vag com i have this:
"1 fault found:
01222 - crash sensor side airbag (G180)
29-30 - short to ground - intermittent"
so.... short to ground i thought would be under the seat as the wires looked to be touching and the sheath moved down a bit... so i taped these up reset the code... but the light came back after a week or so...
Any other ideas?
Where is the crash sensor for the side airbag??? - is it the door panel? or in the seat?
any help much appreciated!!!!!!
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
Its under the carpet bolted to the floor on the front of the crossmember that the front of the seat mounts to kinda area.
struds
cheers....will check it out tomorrow when its light!
take it its likely to be a replacement
or do you think maybe good old tape up the wires?
