Graemeb_dj
HANK
Nov 22, 2009
64
Glasgow
www.bebo.com
Got me bocanegra back today guys! finally after 5weeks in the garage,
What was replaced was .... brake vacuum pump & pipe
Was all good for half an hour after getting it back when the whistling started again every time i touch the accelerator peddle,
Got a full AA Inspection done on the car that night, mechanic rekons its some sort of metal to metal noise and couldnt find anything :S
hmmm can u hear it outside the car or is it inside? because if you press hard on the peddle you can hear the turbo spool up which is like sucking air.............
Mine does the same thing if its a small squeak, you can get it to do it if you feather the accelerator pedal. I'm looking into mine at the moment, done 5000 miles now.
Common problem on the Golf GT etc, its the clutch on the super charger slipping. If you activate the coupling with diagnostics it stops for a short while.
Might be a completely different thing, but i had mine in for a whistling noise, and they said it was the seal on my right wing mirror (because of the cold). They resealed it and the noise went. They also said it had been a common problem with ibizas over the last few months because of the chilly weather.
Hello,
I haven't got an Ibiza but have a Scirocco with the 1.4 engine and am a mod over on Scirocco Central. The whistling noise is really common - apparently it's something to do with the magnetic clutch for the supercharger - VW have been working on replacemnets for it but non of the versions have cured the problem. Apparently it's not a damaging problem just an annoyance.
HTH
Deacon
