Advice on throttle problem needed
robertnitro
58
hi im running a 1997 ibiza 1.4 sxe (aex engine) having a few problems with the throttle at idle and when changing up heres the symptoms:
start up seems ok but in idle when its given a little blip of throttle the engine seems to go down by about 100rpm as if its going to die then it kicks in and revs up,theres a good 2second delay,also under the bonnet when you give it some you can hear a whoosh as air is sucked in but it doesnt seem to want to respond until 2seconds later,theres definately a noticable delay,it only happens from idle and responds instantly if reving from say 2000-3000.theres also a tiny delay when changing up and down until the power comes on,so i have to almost power shift to get rid of it. any help would be greatly appreciated.
this is what ive tried already: complete new ignition parts plugs,HTs,dist cap,rotor,(not coil tho)
Cleaned throttle body bore with carb cleaner,used injector/fuel cleaner in tank,new air fillter,oil and filter change,checked breather and vac hoses
parr112
ive got the same problem with my car, but now mine seems to be stalling when driving its the same model as yours did you find a cure for this or still looking
F2 Ed
now has VAG com
Nov 5, 2006
920
www.superlite-wheels.com
cleaning the throttle body was a good idea. Forget the ignition components
Your idle stepper motor isnt doing its job properly. From memoy its part of the throttle body on the AEX engine you have. If a good clean doesnt solve it, pull the throttle body off a polo or ibiza in a breakers yard. Easy
