Advice on aftermarket headunit
Drewscott
Hello, I have had a look at alot of the threads and have seen some confliting answeres so thouhgt i would see what response i got. I have a mk2 2006 (55plate) reference leon with bluetooth built in and steering wheel control.
Im looking to replace my OEM car stereo and would appreciate advice on the following-
  • How do i remove the OEM stereo (really want to avoid damage!!)
  • Where can i get a facia? Seen a few on the net (A1 motors, DVB audio) and they seem to be a bit more expensive than what i have seen opeople talking about on this site. I have read alot about getting parts from my seat dealer ect but not sure of numbers. any numbers would be good!
  • what adaptors need to be used when fitting a new head unit (its going to be single din with a pocket)
  • does the seat bluetooth still work when there is a new headunit?
  • how do you get into the speakers that are in the doors (both the main and the tweeters) and what size are they
  • what the best way to run the cables from the head unit to the boot (hoping to fit a amp at some point)
Thanks for any help and advice, it really will be appreciated!!
Drewscott
Thanks, that looks like a good bit of help! The only ther question I have is will my bluetooth work with out my OEM stereo? really want to keep the bluetooth set up as it is!
robdf2
Yellow is the best
Feb 21, 2006
3,605
location , location
yes regardless of the make of head unit , as long as it has an auxillary in your bluetooth will work.
Only thing is you will have to change the source button on your head unit to aux , it wont switch automacically , except if you go for the alpine version with the switching box.
Ruuning cables to the back is a pita in the leon , i did one side by removing the trim but did the drivers side by removing the seat much easier , and i am not a newbie to this been installing for over 20 years.
If you change the speakers in the front doors then you need patients of a saint and will find our self going to confession for the next year for all the swearing you do , taking off is easy , but aligning and putting back on again thats a diffeent question all together !
Also to get rca cables up and behind the head unit is another pain , next to no room at all because of the way the centre console is constructed , took me about 2 hours using a coat hanger !
