Advice needed after RR results
R953 VSE
:cry:
After having stage 1 revo two weeks ago i had my car on the rollers on sunday with disappointing results (see below). i have a bmc carbon airbox and forge dv and im pretty sure it should be making much more than what it has. the car itself seems to run fine with no boost leaks, hits 20psi.
i disconnected the maf sensor to check if it was causing problems but its fine, anyone able to suggest anything? im stuck as to what else to try.
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
1) they did it in 3rd?? why
2) it's hot right now - so will have pulled back, especially if using lame fans
3) where's the torque graph?
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
if they did it in 3rd, then they won't have got enough load on the dyno i'll bet
but running tesco 95, otherwise bog stock my wifes was 200bhp/260lbft with no tail off after peak power
