adding dump vale 2 a standard 180 bhp leon
josh312
wats the most u can boost them up 2 without needing todo anything else
josh312
was gone do mine by a boost controller or can u not do that on these
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
The boost is controlled by the N75 valve form the ECU with the set paramaters. You cant just 'up the boost' mate.
Damoegan
Oct 15, 2007
8,993
Newcastle
Revo is not a chip mate, but yes.
Revo is just one company that write a new map for the car that adjusts boost, fueling and timing to give you more power.
Try using the search button mate and search for remap, you will finde all the info you will ever need.
caveo
Remap will cost about 300 quid and you should see around 210 bhp . You will also need to upgrade you dv to a stronger one ( forge 007p @ 80 quid ish )
Faisal
UK's 1st Liquid Yello LCR
May 27, 2008
1,445
Most likely at work
on the subject of boost,how much boost does a 210 LCR have?and remapped to stage 2 (on average) what is its potential?
just getting a feel for things
Lodgey180
WoOoOoOsShH
May 3, 2008
1,046
Middlesbrough
www.mootr.co.uk
so do these dump valves have a wooshy sound ??
lol
