webby
Done a qucik search and couldnt find what i wanted
sooooooo
i bought my car with a usb/aux input port, however i would like to add a cd changer is exchange for this or as well as.
so my question is, how do i go about this?
if its a standard head unit, a changer with the correct connector will plug straight into the port underneath the carpet in the left side of the boot.
if you read my first post i did mention i searched!!
can i fit any CD changer or does it have to a be a standard one?
also would i have to remove the usb connection thing as that uses the cd function on the standard headunit?
btw iv got a ibiza mk3 cupra
I assume you could only use either MP3 or CD changer, simply because there isnt enough buttons to run both. You might be better off just getting a different cd player with mp3 built in if you want both and fit it under the steering wheel or something...
as to whether it needs to be standard, i havent a clue, mines standard and works perfectly.
just get the standerd cd changer will plug in to standerd head unit. Then if u want to keep the lead for the ipod get one of those cassets with the aux lead and hide it behind the head unit this is what i done and looks tidy.
cheers guys, appreciate decent answer rather than saying use search lol
