Adaptation reset???
ian_jobson
272
Medway towns, Kent
tried resetting ecu earlier, left battery off for 10 mins but when reconnected the radio worked fine (didnt ask for a code) and primed ignition and got a buzzing (thought it was the TB re alligning) but it went on for at least 20 mins till i figured it might be the water pump and started her up. once warm gave her sum welly and it boosted fine.... for about 3 mins then reerted back down to 6 again... did i actually reset anything?
ian_jobson
272
Medway towns, Kent
nope, theres another thread in this section called "fitted mew maf but..." that explains in detail, any help would be appreciated!
If it reset everything how comes i didnt need a radio code?
flashbsd
because the radio isnt removeable so theres no point in a code, nobody's gonna nick it!
ian_jobson
272
Medway towns, Kent
just posted vag com codes in other thread but for your benefit martyn (as ur a guru at this hehe)
VAG-COM Version: Release 409.1-S
Chassis Type: 6L - Seat Ibiza
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Address 01: Engine
Controller: 6K0 906 032
Component: 1.8L R4/20VT SEA 0002
Coding: 11500
Shop #: WSC 00000
4 Faults Found:
18048 - Internal Contr. Module (EEPROM) Error
P1640 - 35-10 - - - Intermittent
17965 - Shareware Version. To Decode all DTCs
P1557 - 35-10 - Please Register/Activate - Intermittent
18010 - Shareware Version. To Decode all DTCs
P1602 - 35-10 - Please Register/Activate - Intermittent
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-10 - - - Intermittent
Readiness: 0000 1001
Address 03: ABS Brakes
Controller: 1J0 907 379 AF
Component: ASR 20 IE CAN 0001
Coding: 13404
Shop #: WSC 00000
No fault code found.
ian_jobson
272
Medway towns, Kent
done as you said, took it for a drie for a while.... these returned (i knw the power supply one is cos of batter being disconnected)
VAG-COM Version: Release 311.2-N
Address 01 -------------------------------------------------------
Coding: 11500
Shop #: WSC 00000
2 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-00 - -
Readiness: 0010 1101
Address 03 -------------------------------------------------------
Coding: 13404
Shop #: WSC 00000
Address 08 -------------------------------------------------------
Controller:
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 6K0 920 901 D
Component: 6K-KOMBIINSTR. VDO V02
Coding: 00442
Shop #: WSC 00000
IMMO-IDENTNR: SEZ7Z0Y0724822
Address 56 -------------------------------------------------------
Controller: 6K0 035 186 C
Component: Radio GRO 1V32
Coding: 00401
Shop #: WSC 06402
1 Fault Found:
00856 - Radio Antenna
36-10 - Open Circuit - Intermittent
End -------------------------------------------------------
jambojones10
127
the 17965 - Charge Pressure Control: Positive Deviation fault means your car is overboosting, ie your actual boost is exceeding your requested boost. Maybe a faulty n75 valve?
GaryM
Golf GTI 1.8T 180
Feb 11, 2004
378
Nr Manchester
I believe that the only way to realign the throttle body is with vagcom, the noise you hear when reconnecting the battery whilst the drivers door and bonnet are open does come from the TB but it isn't realigning.
I've read many posts on different forums backing this up.
ian_jobson
272
Medway towns, Kent
so does tht mean itd limit it to 6psi to control the problem?
i want to get a new N75 valve, mines an F. of anyone knows where i might find one at a decent price, itd be appreciated!
jambojones10
127
try logging your n75 duty cycle. log block 118 on vag-com, also log block 115 , tells you your requested and actual boost. Do a run in 3rd gear from about 2000revs to redline
Simon L
Audi TTS
Sep 24, 2004
1,253
Glasgow
When i bought a new MAF off some joker company on eBay, it sent the car straight into limp with a "positive deviation" error.
ian_jobson
272
Medway towns, Kent
was doing it befor i changed the MAF too, the maf cleared one fault so thts working, i dont know how to run logs guys, my local seat it pants only has a parts desk in office hours.... i work office hours!
would limp mode not through on a light on the dash?
