Acceleration measuring, [how accurate]
Sisson
Club member
Aug 18, 2005
1,662
Derbyshire
With the new version of Vagcom you can measure 0-60, 0-100 30-70, 1/4 mile, blah blah,
How accurate is it? and How does it know how far you are traveling???
Regards
Adam
Sisson
Club member
Aug 18, 2005
1,662
Derbyshire
the times it was coming up with were say 7.2 +/- 0.69,
Does that mean it could be 0.69 below or above 7.2 secs?
Riddick_m3
339
Sudbury, Suffolk
ive got a gt tech meter on my phone it uses a blue tooth sat nav reciever to track where you are and will measure 0 - whatever you want, 1/4 mile times, terminal speed ect.ect and gives a full results page when you finish a test too
Sisson
Club member
Aug 18, 2005
1,662
Derbyshire
i have one of those G-tech timers, but im not sure how accurate it is??? especially as its just plugged into the fag lighter/ and has no gps???
Riddick_m3
339
Sudbury, Suffolk
well i dont know what thing you have got then lol sounds like some chewy thing from the front of max power........... mine is software for your phone that uses a blue tooth gps reciever the same thing you use for tom tom mobile then with that it measures 0-60 1/4 mile ect. loads of results even time from 70-100 and stuff like that
OLDOILER
1,292
Wiltshire, UK
I also have a GTec Pro RR , once you have setup the rpm scaling and the CORRECT vehicle weight (including yourself!!!) the system works off 3 electronic sensors.
I have had to do at least 5 runs and then average out the results, it should be within 1/2sec - hope this helps
pickie
222
what is the name of the software for the mobile ??? do they do a version for a pda or is there other software for windows pda's
EddyH
263
Pontefract
Regards
Adam
Distance is calculated from rotations of the front wheels so if you wheelspin then the 1/4mile time won't be particularly accurate. The acceleration figures shouldn't be that far off though as already discussed.
