Abs
shiller1984
Hi i've got a fault on my ABS system i did a search but i couldn't find an answer as to which bit to replace for definate :confused:
This is what it comes up with:
01276 - ABS Hydraulic PUmp (V64)
16-10 Signal Outside Specifications - Intermitant
This is on a 1.6 Cordoba
i've read that it may be the controller, a fuse or the pump, which one do you think i would be looking at more than likely, i'm gonna check the fuse later (somewhere under the bonnet it says)
Also is it safe to drive with this light on? :blink:
Thanks Simon
Tallpaul
821
i had the same fault on my Audi A3.
Check the fuses on top of your Battery and then trace all the wiring from the ABS controller and check for shorts/damaged wires.
I had a blown 30amp fuse and a damaged positive feed to the ABS controller.
