Abs
sambo19
sambo
Oct 20, 2006
104
worcester
was reading through a thread on here about turning off abs the other day. but i didnt realise that there was meant to be an abs light at ignition for a couple of seconds which made me think if my abs even worked, so lastnite wen it was wet i went out and tried out my abs by braking hard on a fair few occasions and the wheels locked up, so im guessing i have no abs. i checked the fuse under the dash which is fine but i also read in the manual there are some under the bonnet but i have no idea where. could anyone help me out on this by possibly sendin me a pic of where i should be looking? and also cud it be anything else?!?! cheers
jcs356
Cordy owner
Jul 12, 2004
1,161
Englandland
What year is your car? I don't think ABS became standard on the GTi until at least the 1995 model year (registered from late 1994 onwards). That coincided with when Seat dropped the GTE model from the line-up, which I believe did have ABS and an airbag as standard.
My GTi (Jan 1994) doesn't have ABS, an airbag or aircon.
sambo19
sambo
Oct 20, 2006
104
worcester
sorry the year and wot it is would be a good start!! its a 97 gti 2l 16v, definatley got abs as iv seen the abs module under the bonnet. iv only had the car a couple of months and really dont know anything about the car yet.
edc
Blue Leather & Shiny Bits
Feb 8, 2002
8,142
Surrey
www.clairecoileytrust.com
Sounds like somebody has tried an MOT type fiddle as if the ABS is not working then the light in the dash should be on. Check that you have a bulb in the correct place. A quick diagnostic check should pick up a duff ABS sensor.
Sep 20, 2006
756
Birmingham
I thought even if you do have ABS that your wheels can still lock when braking hard. It just allows you to steer when they do lock up.??
Hayz
Cheeky
Apr 5, 2006
473
Portsmouth
www.drive4fun.co.uk
No your wheels shouldn't lock up.
When you slam the brakes on really hard when you have abs the brakes open and close really quickly (you can feel it through the pedal). Which stops it from locking up.
x
studioeng
R.I.P. SXE. Hello Salsa!!
Feb 12, 2007
76
Dorset
www.byattsystems.co.uk
I'm still waiting for my damned Haynes manual to arrive, but can you help me to find out if I've got ABS or not; heres a photo of my engine bay:
Where would the ABS system be; so I can find out if mine does have it or not.
[rant]
It's supposed to be an SXE model, but I can't find any information about that model anywhere ... Which is getting mildly frustrating ... Which means I need to ask stupid questions.
[/rant]
:blink: oO( Studioeng's Idiots Guide to Cars ... )
Kai_1600
Shallow
Dec 10, 2005
410
Manchester
is it s 1.4 or 1.6 SXE I now my 1.6 SXE (97 R reg) doesnt have ABS as a few hairy moments on welsh back roads has taught me :)
studioeng
Feb 12, 2007
76
Dorset
<<<< Theres your answer!
So you can use the search function, but you can't read posts :confused:
:cartman: oO( Take note of the TDi in bright red on the front grill and embosed on the engine cover; and that MK2 TDi's are only available in 1.9 )
