ABS, TCS lights on car goes mental!!
damo toledo
(toledo 1.8 20V AUTO 2003)
ABS and TCS lights came on and car slowed to 5mph auto speed (even with foot to the floor)
Stopped left for 10 to 15 minutes...started it again, it started OK drove 20 yds or so
then car alarm went off with all lights flashing and not many revs as if it was gonna return to the 5mph auto speed
any1 know how to solve this?
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
first plan of attack would be to plug in diagnostics and see if there is any previous recorded issues or broken parameters the ecu has recorded
might help narrow down any possible causes and give you an idea where to start
check over all your lights and levels etc first to make sure all is well
damo toledo
Lights and levels ok, no previous recorded issues or broken parameters
damo toledo
used info found in a previous thread which had the vag com diagnostic
i just cleaned the battery using sandpaper, car is fine now ;-)
