Phill I'm having this same
problem.
This is what I posted in Dannylads thread:
Danny, interesting you should say this, as I had problems with my ABS as my tire rubbed into the wire going to the ABS sensor on one side. I fixed that and now the ABS TCS lights come on ramdomly. Then when I turn off engine and turn it on again, the TCS light goes off and after driving 10 seconds the ABS goes off. That sound anything like what you had?
He had similar problems and turned out to be the fuse under dash. I haven't replaced mine yet but will do this weekend.
My
problem sounds like yours. I did clean the connections though.
You getting lights? or an occasional ABS sound when it kick in when it shouldn't?
