It all started when I changed a AC pipe in the engine bay, I had to unplug the 3 fuel lines (next to washer bottle) and the coolant pipes that go in to the bulkhead, all put back fine and car runs fine even the AC works now it's be filled up. BUT now I'm getting these faults and ABS TC lights on dash......
Control Module Part Number: 1J0 907 379 AF
Component and/or Version: ASR 20 IE CAN 0001
Software Coding: 13404
Work Shop Code: WSC 00000
3 Faults Found:
00283 - Front Left ABS Wheel Speed Sensor (G47)
35-10 - - - Intermittent
16-10 - Signal Outside Specifications - Intermittent
00285 - ABS Wheel Speed Sensor: Front Right (G45)
I've had the wheels off both sides and check for stones/gunck stuck in the router sensor both clean, the wires looked ok.
Is there anything else i can check or could it be anything else none ABS?
I don't want to spend aload of money on parts to find it was somthing simple.
Also is "front right" viewed from in the car or from the front i.e front right = drivers side?
Olly
3 Faults Found:
Olly
