Lady Pandora
Hi everyone
I have a cupra FR TDi, was driving home the other day, slowing up to stop at a roundabout and the car felt like it skidded slightly (and I wasn't braking particularly hard). Next thing I know the ABS and TC lights are on and they have stayed on ever since. Also when you brake suddenly both wheels lock up. The ABS pump seems to be ok, could this be the sensors?
Any help would be greatly appreciated. :)
need to check the codes mate, mine went like this and was a weheel sensor down , but as said you need some code reader or someone with vag com to see what and which one if its the above to replace not expensive was about £20 for the part
yeah i had this happen to me aswell, it was just the wheel had burnt through the ABS sensor on the drivers side front wheel , also if you need a new plug i have a brand new one spare.
Cheers guys, how much do you want for the sensor and cable?
