abit of a Hummmm.....from Nearside front
CupraCal
53
Stamford
How do all, just thought id ask on here to see if my thought are right or wrong... if it is in the wrong the please let me know :)
basically when i first start the car and drive off for abit if im going say 20mph or slower the rear left side break seems to make a humming sound. now i think its either the pad rubbing on the disk as its cold out or theres a stone stuck in it... But when i press on the break it stops then might return later.. can anyone please advise? also i think the front left wheel bearing might be on the go but can anyone tell me some tail tail signs or bit to look out for.
many thanks guys & girls!
cal
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
could be bearing mate, jack it up and hold hands on 12oclock and 6 oclock and see if theres any play in the wheel, if there is its the bearing.
Witalik
ROTTERDAM FEYENOORD
Dec 28, 2008
324
Netherlands
i also have this sound when i drive in reverse and i brake looks like there is room on the caliper bolts or something ??
Husbandofstinky
Out from the Wilderness
Nov 8, 2007
1,515
12
Temperate Regions
Might be worth servicing your brakes - clean up and copper grease in the right areas.
There's been a lot of grit on the roads.
Whilst jacked up whip the wheel round to see if pads are sticking.
CupraCal
53
Stamford
ok ill have a look with a mate of mine being a mechanic has its +'s lol cheers for the info i got my mate to stick his head out of the window and have a listen n he said it was coming from the rear left side wheel :S
