ABF aftermarket cams opinion
SA Polo
92
South Africa
www.vwclub.co.za
So its time to change cams on my ABF motor, and im thinking of a combo of 268 intake with 11.1 lift, and 272 exhaust with 11.4 lift.
The motor already has port and flow work to the head, with racing header and will be fitting a 63mm 2 box system in the next two weeks.
What combinations of cams do work well?
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
should do apart from idle fueling might be upset.
apparently 260 cams are about all the stock ecu can handle on idle lambda control.. so it might not pass emissions if thats a problem
