a VERY VERY poorly mk2 Leon Cupra
gazprice79
50
Hi please can someone help me, i know im going to have to take it into the garage for this one but can any tell me what they think this problem is.
firstly i pulled out and car lost power and began to missfire something rotten ive gently nursed it home and plugged in the VAGCOM the scan read as follows
Saturday,26,March,2011,20:26:41:04643
VCDS Version: Release 10.6.3
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Control Module Part Number: 1P0 907 115 C HW: 8P0 907 115 B
Component and/or Version: 2.0l R4/4V TFSI 0020
Software Coding: 0303000318070160
Work Shop Code: WSC 62016 476 95091
VCID: 2B7BD65AF383
4 Faults Found:
008801 - Boost Pressure Control Valve (N249): Mechanical Malfunction
P2261 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Mileage: 76082 km
Time Indication: 0
Date: 2000.00.00
Time: 17:29:58
Freeze Frame:
RPM: 4910 /min
Load: 8.6 %
Speed: 91.0 km/h
Temperature: 65.0°C
Temperature: 16.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 14.478 V
000566 - Manifold Pressure / Boost Sensor (G31): Implausible Signal
P0236 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 76082 km
Time Indication: 0
Date: 2000.00.00
Time: 17:30:13
Freeze Frame:
RPM: 828 /min
Load: 17.2 %
Speed: 0.0 km/h
Temperature: 78.0°C
Temperature: 19.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 14.224 V
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - Upper Limit Exceeded - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 0
Fault Frequency: 1
Mileage: 76273 km
Time Indication: 0
Date: 2000.00.00
Time: 19:52:08
Freeze Frame:
RPM: 2353 /min
Load: 35.7 %
Speed: 18.0 km/h
Temperature: 54.0°C
Temperature: 15.0°C
Voltage: 14.351 V
000772 - Cylinder 4: Misfire Detected
P0304 - 001 - Upper Limit Exceeded - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 76273 km
Time Indication: 0
Date: 2000.00.00
Time: 19:52:08
Freeze Frame:
RPM: 2700 /min
Load: 46.3 %
Speed: 21.0 km/h
Temperature: 54.0°C
Temperature: 15.0°C
Voltage: 14.351 V
Readiness: 0000 0000
Car has had Revo stage 1 and a Forge twintake.
Before it did go completely tits, it did occasionlly drop power for a fraction of a second under constant speed/acceleration.
Any comments or help would be greatly appreciated
Gaz
Lee M
I've had a similar thing for ages. I can pretty much make a slight misfire occure during acceleration in 4th around 3500-5000 revs (which i'm presuming is maximum load). no codes on vag com.
Today however i got a ecu light flashing at me. Vag com revealed multiple misfire and cylinder 1 misfire.
I rekon i have a dodgy coil pack or plug, similar set up to you too.......might be worth whipping your plugs out for a check as the first prt of call.
gazprice79
50
Sorry should have updated i replaced all the coil packs and spark plugs since which ye solved the immediate problem but my car still has an erratic misfire and has been in awesome gti for nearly 5 weeks trying to identify the problem they think its an air leak somewhere and investigating further.
WeeG
3,407
Largs , Ayrshire
Unfortunatly i know of a few standard 60/11 plate cupra tsi and S3 tsi's who have had the exact same ideling and missfiring problems from new. One of the boys with the S3 have threatend the dealers to get it sorted or they can have the car back as it is only 7 weeks old :-o
